LabVIEW FPGA Idea Exchange
gsussman
Prompt the user when an FPGA compile has completed
Status: Completed
Available with LabVIEW 2010 FPGA Module.
I know that when connected to the compile server the local compile status window will show you when a compile is done, however that does seem to severely limit productivity in that the only way you can get back to working in LV is to disconnect from the compile server. The downside is that you don't get any feedback as to when your compile has completed. This is especially true if your compile server is running on a remote machine.
Why not add a feature to LabVIEW to allow disconnecting from the compile server but still provide a background polling feature to update the user when the compile has completed. Something as simple as a dialog box telling me that my compile is ready would be great. It would allow me to get back to work on other sections of the code while still closing the loop on the running FPGA compile process and alerting me that it is done.
If the system polled once every minute or so that would be more than adequate.
Greg Sussman
Sr Business Manager A/D/G BU
1 Comment
Dragis
Active Participant
Status changed to: Completed
