Typical Xilinx IP core icon like FFT and DDS looks like this - in expanded mode:
The connector labels are very hard to read. I guess everybody agrees on that this could be improved. And it is not that there is a "standard" narrow width to obey, for instance FIFO is wider than the Xilinx IP icons.
Thanks for considering this.
