LabVIEW FPGA Idea Exchange
Spectre_Dave
Sort Controls in Read / Write Control (FPGA Interface)
Status: New
The Control / Indicator pull down menu gets unwieldy with a lot of Controls on the FPGA Front Panel.
I would like to be able to sort the names alphabetically so they are easier to pick in the pull down list.
Visualize the Solution
CLA
LabVIEW, LabVIEW FPGA
3 Comments
LVB
Active Participant
Active Participant
This can manually be accomplished by setting the front panel tabbing order of the controls for the FPGA VI.
CLA, CTA
JKSH
Active Participant
This idea deserves a lot more votes, especially since we can't mark certain controls/indicators as private! It would be great if the IDE could let us choose the sorting criteria (although I can't think of any case where tabbing order would be the best criteria)
Certified LabVIEW Developer
James_McN
Active Participant
I really want this idea. I have taken to using the same sort of naming conventions as the VST projects, where you define group.parameter as the name, so like 9223.Sample Period
With these then sorted this will be much easier to work with, even better if it could make submenus based on this 🙂
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
