I'd like to have a dedicated FPGA Compile Server, based on a realy slim OS, e.g. damn small linux oder even PharLab? The OS does not realy matter, as far as it is multi-core capable and it should use as little system resources as possible, to get as much ressources as possible for the compilation process.
Purpose: get max. compilation speed
