Add a description of inputs and outputs relative the the chosen polymorphic instance of the VI.
Current documentation is Axis 1, Axis 2, Axis 3 and there is no description e.g. how those names correlate to the polar coordinates Phi, Theta and length!
I had to figure it out by trying - please just add tose few lines to the Labview help!
Moved to CAR database: CAR 503133
