Hello:
I am going to be testing the 64-bit version of LabVIEW soon. But the major code that I want to port to it also uses Vision and Advanced Signal Processing Toolkit. Therefore, I am VERY, VERY interested in 64-bit versions of those toolkits. I work at times with 100s of high resolution images and to effectively have no memory addressing limitation that 64-bit offers will be a significant advance for me. Right now, I post-process with the 64-bit version of ImageJ to do some of the work that I need with huge image sets.
