Poema
A list of nice to have
Status: Declined
Maybe there are some of them already existing, but this list is based on my experience.
-          Read and write connection to each variable
-          Highlight execution only for a selected area or block
-          Possibility to change the Highlight execution speed
-          When the grid is activated
               Snap wiring to grid
               Size icons and blocks automatically to grid
               Snap connections to grid
               Align and size cases, loops, sequence, ... to grid
-          Search option for a combination between object and text
-          Logging and alarm properties for shared vars in cRIO
-          Modern set of valves and pipes
-          Cleanup wiring within selection
-          Preview wiring while moving items
4 Comments
crossrulz
Knight of NI
First of all, 1 idea per thread.  With a long list like this, how is NI going to know which one to go after?
Do a search before posting.  A majority of those ideas are already in the Idea Exchange and/or implemented in LabVIEW.
AristosQueue (NI)
NI Employee (retired)
Do you mean find the reads and the writes of a variable? This already exists when I right click on a variable, I can find its usages. If you mean something else, please file a new Idea to explain this further.
This idea already exists in the Exchange.
>Whenthe grid is activated
>               Snap wiring to grid
Some parts of this idea already exist in the Exchange.
This is a new Idea. A good one. Please create a new Idea entry to explain it further.
I do not know exactly what you're asking for here (cRIO is not my specialty). Please check for an existing idea.
This is a new idea. Please create a new Idea entry to explain it further.
This is already done. Select a subregion of your diagram and hit Ctrl+U.
Not sure what you mean by this one. As far as I can tell, this already happens -- wires are shown while dragging and autowiring previews if anything is going to kiss together. Please create a new Idea and explain this request further.
I will ask the moderator to decline this megaidea as it really cannot be discussed as a block.
MaryH
Status changed to: Declined
Poema
Thank you for the effort, AristosQueue
It saved me a lot of time, searching for every item is time consuming and, I suppose, You have already a big list in your personal memory. I don't know if there is an email system for the idea exchange. (e. sending the last 10 new items and let them answer with a vote for one of them). In that case we are automatically up to date.
>Do you mean find the reads and the writes of a variable? This already exists when I right click on a variable, I can find its usages. >If you mean something else, please file a new Idea to explain this further.
 I find it ==> "Allow Wiring to Determine Property Node Read/Write"
>When grid is activated
>               Snap wiring to grid
I will create a new idea
I can not find it, I will create a new idea
This is not the same, what I mean is cleanup the WIRING not the diagram
>Not sure what you mean by this one. As far as I can tell, this already happens -- wires are shown while dragging and autowiring >previews if anything is going to kiss together. Please create a new Idea and explain this request further.
This is of less importance we may omit. (it's like in siemens SAPRO, a graphical language for a siemens controller)
