Several points related to the popup menu.
(1)
In a popup, directly activate a submenu.
a) This creates a menu file (*.rtm) with all the popup menu (as does Microsoft).
b) This opens directly into a popup menu, part of the application main menu.
(2)
Able to choose where opens the popup (default position of the click).
(3)
Have a model of development (as for X-Control) to create its propore popup menu from VI.
This would create 'popup' with many functions.
(4)
For lists, arrays (1D or 2D) to obtain information directly from column, row and icon.
Systematically using the method "Convert a point to line-column"
Actual we have :
It better with
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
