13 | |
7 | |
3 | |
3 | |
3 |
Struggling to replace R&S FSW-K70 by VST and RFmx for my customer, found 16APSK and 32APSK are not directly supported by RFmx DeMod. The customer is currently using FSW-K70 and their current test scnearios require 16APSK and 32APSK modulation and demodulation.
I found a thread mentioning about APSK support below.
https://forums.ni.com/t5/LabVIEW/APSK-Modulation-Demodulation/td-p/4232293
