10 | |
3 | |
2 | |
2 | |
2 |
If you are not using the Data Event Terminals in an Event Structure, you might customarily hide them - roll them up so that only one terminal is showing. I would like to hide that remaining terminal. The idea is to not grey-out the Remove Element option when you are down to one terminal. That way, you can remove it. A stub remains to right-click on in order to bring the terminal(s) back if required.
Available in LabVIEW 2020 and later. You can hide an unused event data node within a notify event frame by right-clicking the event structure and unchecking 'Visible Items > Event Data Node for This Case'.
