11 | |
11 | |
3 | |
3 | |
2 |
I would like to be able to group decorations on the block diagram. In the attached simple example, I have to keep up with nine items - always selecting the entire area to move it.
The current work-around for this is to place the items in a structure, such as a single frame sequence.
