3 | |
3 | |
2 | |
2 | |
1 |
A chart can be used to display each channel of acquired data on its own separate plot area for comparison with a common time axis. If the number of channels varies in a running program, the number of plot areas should be changed, perhaps by changing the Number of Legend Rows. The number of plots in a stacked chart cannot be changed at run time however. This issue is known to NI but apparently is not an easy fix maybe due to memory allocation issues. I am posting it here in hopes of showing enough interest to get this some attention.
http://forums.ni.com/ni/board/message?board.id=170&thread.id=296053&view=by_date_ascending&page=1
