13 | |
7 | |
3 | |
3 | |
3 |
The Project page of the Project Properties window contains the Mark Existing Items... button. When pressed, this button enables the programmer to enable the "Separate Compiled Code" setting for all files in the project. This is very useful.
Suggestion: It would be useful to have similar functionality that could enable or disable Automatic Error Handling for all VIs in the project. This could be achieved by adding a drop-down menu that enables the programmer to select whether they want AEH to be enabled or disabled, alongside a button that enables the programmer to apply the selection for all project items, as seen below.
Notes
Although we are looking at ways to make debugging more of a project-level concept, we're not planning to do our own version of a tool like Property Inspector Free Toolkit for LabVIEW - Download - VIPM by JKI.
