6 | |
5 | |
2 | |
2 | |
2 |
Tab controls can be scaled to fit a pane, and that's great.
The problem is when you have objects inside a tab control. For instance: a sub-panel container or a multicolumn listbox.
Unfortunately, these items can only be set to fit/scale to pane, and not to the bounding area of the tab control.
I propose an idea to allow an object to be set to scale with a tab control's page. This will allow the tab control to scale with a pane. Embedding a sub-panel container into a tab's page will allow a great amount of configuration since the dynamically loaded vi can handle scaling on it's own. (hint: you can then have splitters inside a tab control)
