When creating large state machines or using structures that have a lot of code in them, we come to a situation where the structure becomes incrementally larger as we develop. A structure can easily expand with small actions, however, if we later want to shrink the structure it is not so easy, especially with case structures.
I'd like to have a way to lock a structure in place so that it is impossible to expand it unless it is unlocked. That way it will help keep the code neater and also force the use of subvis in places where there is a lot of code. An option on the context menu would work.
Another option would be to lock the structure such that code could not expand it, only by intentionally clicking on the edge of the structure and resizing it could.
