13 | |
11 | |
3 | |
3 | |
3 |
There are times when I leave a VI with modal properties open and then I run the main application that also calls this VI if opened in the development environment. This locks all running windows due to the modal VI. I propose a button in the taskbar that aborts all running VIs OR perhaps a list is opened on right-click of all running VIs 🙂
