If you e.g. open a project in a newer LV and then close it; it starts recompiling everything with no abort option, and only after having recompiled 2000 VI's i can choose to _not_ save them ...
I just opened it to check a few things and ended up with Kill Process to get out of it.
Let us cancel/abort the recompile when shutting down.
