Using the 3D Surface Plot in LV2011 it is possible to switch on or off either "Surface", Mesh" or "Normal".
Being in the need of the surface normal angle for some calculation I was told that this data is not accessible through property nodes.
I would really prefer accessing this data instead of calculating it twice!!!
And by the way: Displaying large data arrays in 3D Plots takes computing power running on one core only. Wouldn't it be possible to have a parallelizing option here...
