6 | |
2 | |
2 | |
1 | |
1 |
It would be helpful if we could create raw IP sockets in order to have access to protocols other than TCP and UDP. This would open the door for LabVIEW to be used for general network testing. I would be fine if this extension meant the programmer was responsible for implementing the protocols. Simply having access to a raw IP socket would be a benefit.
