10 | |
3 | |
2 | |
2 | |
2 |
Batch message class should have a public static method to build a batch message that can be sent to the Time-Delayed Message.vi.
I would like to wait xxxx ms then send three messages in order.
Yes there are twelve other ways to do this but this would be much cleaner and it is an easy one change.
