I wonder if newly created wire labels should inherit the wire color for better clarity. Labels on array wires (and other thick wire thingies, clusters, objects, etc) could go bold for the same reasons.
(Of course the programmer can later freely change these label text properties)
While this is an interesting idea, it has a low return on investment for the work required to do it correctly and therefore will not be one of the things addressed in LabVIEW.
