Incorporate NI Batch Installer Builder into the general application builder suite.
This tool has a lot of potential for end-user use if it is incorporated into the app builder API and suite. Batch installers can be used for much more than just installing selected sets of NI software (Which this tool is obviously designed specifically to do). It could be used for creating installers of multiple, cross-project user installers comprising a complete system. To do this though, the current batch installer builder needs to be made more generic to be of use.
Specifically:
Including this in the app builder would be even better since that should allow project based configuration and control of the batch configurations and potentially even programmatic control.
