Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
No. Definitely not.
If anything then OpenCL, not CUDA.
Please check
http://decibel.ni.com/content/docs/DOC-6064
@Muks. Yes that's it.
HERE's a link to OpenCL (which is actually based heavily on CUDA but has the reasonably large advantage of being multi-platform and vendor-independent).
Shane
