MichaelAE
Add Connect as Option to Connector Pane
Status: Declined
Add Connect as an option when right clicking on an empty Connector Pane Terminal. In addition to single clicking, since you can right click and disconnect it would be nice to also be able to right click and Connect a Terminal
3 Comments
JasoNI
NI Employee (retired)
Similar to property nodes with the "Link to" option
SteenSchmidt
Trusted Enthusiast
I first thought; "Why, this is the primary action you do on the conpane with left-click?". But JasonAE suggests that you mean so you can select from a list what to connect to, instead of hunting around on the FP - is that it?
/Steen
CLA, CTA, CLED & LabVIEW Champion
Darren
Proven Zealot
Status changed to: Declined
