JB
Add Copy/Paste to Quick Drop selection
Status: Already Implemented
Ctrl-X, Ctrl-C, and Ctrl-V shortcuts for cut/copy/paste do work in the Quick Drop text box as long as there are not custom keyboard shortcuts associated with those keys.
In some cases, it would be very useful to be able to copy and paste the text of the selection box.
8 Comments
elset191
Active Participant
As someone who has set a shortcut as Ctrl-X (against Darren's recommendation for this very reason*), I object.
*There's documentation of that exchange somewhere on the internet, but I can' t find it.
Tim Elsey
Certified LabVIEW Architect
Darren
Proven Zealot
If you don't have custom shortcuts assigned to Ctrl-X, Ctrl-C, and Ctrl-V, then they will perform cut/copy/paste actions within the Quick Drop text box. So this functionality is already available. Am I misunderstanding your idea request?
JB
Trusted Enthusiast
Trusted Enthusiast
Thank you Darren. I have just noticed that Ctrl-C is used by the QD_CaseSelect plugin.
Darren
Proven Zealot
Good deal. So is it ok with you if I close out this idea?
JB
Trusted Enthusiast
Trusted Enthusiast
Yes. Thank you for your clarification.
I installed this plugin only a few days ago and had never tried to copy/paste before !
Even this is not the best idea, can the default shortcut of a plugin be changed ?
crossrulz
Knight of NI
The default shortcut is actually derived from the VI Description of the plugin VI.  It is the key inside of the brackets.  Or you can just simply change from the default using that configuration window.
JB
Trusted Enthusiast
Trusted Enthusiast
Instead of typing only the key, I tried to change the shortcut by typing the whole key combination. Therefore the Set button of the QD Configuration window remained greyed out.
Many thanks for helping me to become a little less stupid !
Darren
Proven Zealot
Status changed to: Already Implemented
