When you have to handle events, many times you have to use "defer panel updates" fonctionnality, in order to make your front panel updates more fluent.
It could be nice to include a checkbox in the event configuration window, in order to ask (or not) an automatic defer panel Update.
If check box is checked :
Manu.net
