6 | |
2 | |
2 | |
2 | |
1 |
Automatic formatting for numbers has limitations.
For instance:
may in fact be hiding:
It's a recurrent problem which I have no good solution for as a LV user (unless I spent tons of code to check the size of each numeric control, the number value, etc). As a follow up on my comment to this "ellipsis" idea, I would suggest having an option to have a "tip strip" showing the complete series of digits of a numeric (of course, keeping the display format chosen by the programmer), in addition to being able to warn the user that the full number cannot be displayed, like this:
Ideally, this would be implemented WHEREVER a numeric indicator is used (Graphs, Array Index, you name it).
Feel free to chip in.
