>Is there a valid and logical reason why we are unable to create a static reference to a decoration if the refnum can already be found indirectly via vi property nodes?
No one did the work to have this, as already suggested? Even if something makes sense, it doesn't mean the effort will be put into it.
Like I said earlier, if this is important to you and you don't want to use the control trick, you could use the "set a tag on the decoration trick". This is the RCF plugin I was referring to and if you have LV 2015 and later, you could adapt it to work with the native popup menu system or you could do it as a Quick Drop plugin:
