| User | Kudos |
| 1 | |
| 1 | |
| 1 | |
| 1 | |
| 1 |
As of LabVIEW 2010, the Class Properties dialog includes a page for Documentation, which includes a Description field. There is, however, no File menu and therefore no option to print out the documentation for a class.
This suggestion is to add such a menu and on that menu an option to print documentation, along the lines of what VIs and controls already support. The option should support printing documentation for the class, including all its components (attributes--via the control--and methods).
I have made this suggestion previously through NI support, but wanted to capture this on this forum as well.
