6 | |
6 | |
3 | |
2 | |
2 |
Currently if code is already written, it is difficult to put it into a sequence structure, splitting the code into multiple frames, without breaking wires. It would be great if when I right clicked on the edge of a sequence structure and chose "add frame after" it allowed me to draw the next frame before placing it.
I would also like to be able to selectively split an existing frame up
Wouldn't this be easy and intuitive?
I tried to look for other ideas like this on the exchange and all I found was this but he was a little confusing in explaining his idea and how would it work.
