| User | Kudos |
| 13 | |
| 12 | |
| 9 | |
| 4 | |
| 3 |
Some customers have indicated an interest in modifying a build specification revision programmatically. The purpose for this is to synchronize the build specification revision with subversion software.
Although the revision can be entered manually in the build specification, customers would like the option to update the build specification version either in a Pre-Build VI or LabVIEW program. Using property nodes to access build specification properties would be a useful way to implement this feature.
