Currently the IMAQ (Vision) display windows maintain a separate event queue which can only be accessed by polling for new events. This should be integrated into the LabVIEW event handling so that all IMAQ events (e.g. Click Event, Draw Event, Move Event, etc) can be event sources for the Event Structure.
Any idea that has received less than 9 kudos within 9 years after posting will be automatically declined.
