As a service to trivia buffs everywhere, as well as helping us help people with different LV vintages, I would really appreciate it if the LV help detailed the required version for the various functions and VIs in the palettes. A simple indication in the 'Requires' field would suffice. The more the better, but at least start with recent/new additions and work back. "When was that added?" is a quite common theme.
