Add a quick way to start a new LV project in the folder where you want to save it.
You can add anything you want to the new files menu with the windows powertoy 'TweakUI'
http://www.microsoft.com/windowsxp/Downloads/powertoys/Xppowertoys.mspx
Create a blank project/template project and save it.
run TweakUI open the Templates section and click create, then navigate to the empty file
