6 | |
2 | |
2 | |
2 | |
1 |
Problem is that sometimes a front panel control is so big, that it takes up too much real-estate. (Especially, if you are using a lot of elements within a cluster.)
One nice solution, would be to allow the control to be collapsed down to an icon of some sort.
This can easily be demonstrated by the similar behaviour of references that allow the option to "show control".
From this..... To this...
