MGould
Add Support for Temporary Tables in the Database Connectivity Tool Kit
Status: Declined
Currently the Labview Database Tool Kit doesn't support returning or working with temp tables in a stored procedure.  This makes a SQL/Labview developer have to make complete hacks (such as returning tables in comma delimited form) to return results that take multiple table manipulations to generate.
See this thread for an example:
http://forums.ni.com/t5/LabVIEW/SQL-Query-Works-in-MS-SQL-Server-2008-but-not-when-using/m-p/2151492
4 Comments
Michael.Patterson
Please add support for temp table return vales to the DB toolkit. I am finding that querys are duplicated and being written in unefficient ways to provide work around to be able to pass the data that Labview will be able to access. We have many existing querys that are used on our ERP system for reporting that we would like to access to automate in Manufacturing via Labview. I am having difficulty getting them rewritten by IT since they work fine with all other environments and have proven performance.
Darren
Proven Zealot
Status changed to: Declined
JonathanDC
I would like to give this a kudos, but I can't since it has been declined.
R^2
Just a quick update, tim_vhd found a solution using the toolkit.
Here is his post:
https://forums.ni.com/t5/LabVIEW/SQL-Query-Works-in-MS-SQL-Server-2008-but-not-when-using/m-p/336702...
