| User | Kudos |
| 11 | |
| 7 | |
| 6 | |
| 5 | |
| 4 |
When manually analysing a project, we can set the target in which the VIs should be loaded. Unfortunately, VIs with RT code are often broken under windows, leading to wrong test results, or even worse, pop-ups asking for VIs.
Please add an Application Reference Input for the VIAn Run.v.
Maybe this option could also be useful set in the VI Analyzer configuration file?
