| User | Kudos |
| 11 | |
| 10 | |
| 7 | |
| 5 | |
| 4 |
In LV 2011, an asynchronous Call By Reference feature was added to LV. This feature added a new node called the Wait on Asynchronous Call node. This new node has a timeout that is configured way way of a right click menu option.
It would be nice if the timeout was specified by way of a normal input that can be wired. This has several advantages:
