11 | |
8 | |
3 | |
3 | |
2 |
If we have a horizontal axes (x-axis) scroll bar, why not a vertical one (y-axis)?
When doing plots for geological logs the vertical axis is used as a depth scale and users always scroll in a vertical direction. I had to improvise this in LabVIEW and it took alot of code to handle the rapid successions of scroll bar change events that get generated if a user uses the generic labview scroll bar to scroll a chart.
Anthony L.
Any idea that has received less than 6 kudos within 6 years after posting will be automatically declined.
