Hi all,
This proposal is about adding a contextual zoom for Labview, but it is NOT a full zoom feature!
According to NI policy: Sub-vi have to be used instead of large vi. So the zoom features are not encourage.
However, Zoom out is already existing right now in Labview using the Navigation Window (Ctrl + Shift + N) in full screen
as explained her :
So, why not transform this into a Contextual Zoom, it could be very efficient to navigate into a vi. as proposed here:
Hope, you will like this proposal
Any idea that has received less than 6 kudos within 6 years after posting will be automatically declined.
