| User | Kudos |
| 11 | |
| 10 | |
| 7 | |
| 5 | |
| 4 |
When you want to find out where exactly a control is located on a computer screen (for some dark reason), there is a method for Panes called 'Convert Pane coordinates to Panel coordinates'.
However there is no easy way to get the owning pane of a control!
The propery 'Owner' of a control always returns the actual VI, not the pane.
Ton
