I thought this would be useful in many scenario. Most often we do require to transpose the 2D Array after bundling some 1D Arrays. So, like the Concatenate Array option in the Build Array function, a Transpose Array function would be very helpful, reducing one another explicit node on the BD.
Any takers... ?! ![]()
P.S.:- I did a search before posting this idea, but it yielded zero result.
