6 | |
6 | |
3 | |
2 | |
2 |
Sometimes, when debugging code, I may force a situation, e.g. force a boolean to be TRUE or FALSE, or force a For Loop to only run once. Once I have made the fix I then forget to reverse my changes and run my code. Or, even worse, create an executable and send it to a customer. Doh!
Could we create a primitive, in the shape of a small bug, that I could drop in my code at the point where I force the code? Then, when I come to run a popup asks "Run with bug?" This would allow me to debug my code, but would also remind me to undo the deliberate bug before I run the code for real or try to create an executable.
