13 | |
11 | |
3 | |
3 | |
2 |
For modern application development we need better methods to detect wheter our application is called to open a file.
Currently the only help NI gives is based on command line parameters. And we need to jump through loops to get it working to react on opening a file when the program allready runs.
This is a major showstopper in creating professional applications.
LabVIEW 8.2 had a hidden event for getting this event, which unfortunatly doesn't work in later versions.
