I often use the "Find" text to find where objects are set or where values are changed within the code. Usually when debugging or implementing new code. Often, I search the same text to lookup all the VI's or areas within VIs that has been affected by a change.
It would be great to have a pull down to select from a list of recent text entries instead of having to type the word over again. This avoids any typing errors due to typing too fast, dyslexia, old age or plain old lazyness.
This feature already exists in CVI. Why not have it in LabVIEW?
