I would like to drag items such as the iteration terminal and conditional terminal to the corners of a structure(i.e. while loop) and have the snap to their default locations,much like the way labels will snap to their respective controls, indicators, and constants when you drag them near the item. This becomes a problem when you wire something to one of these terminals and then resize the loop or structure. The terminals remain where they are currently located instead of moving with the structure boundary.
