10 | |
3 | |
2 | |
2 | |
2 |
Hello, I would like to be able to copy a configuration for a specific variable in fuzzy system designer. It's very tedious to specify the ranges and the values for those variables one by one. In some cases there are many variables that are configured in a very simillar way. There should be a copy button next to them.
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
