To reduce the amount of time to have shift to Front Panel when in need of changing a array control/indicators dimension. I suggest that to add two right rows in the right click menu is added; "Add dimension" and "Remove dimension" on these terminals on the diagram.
Writing this I realize that these two new menu options could be available on single element indicators too for easier transforming single element into arrays.
