 HenrikDueholm
			 on
		08-08-2018
		03:12 PM
			6 Comments (6 New)
			HenrikDueholm
			 on
		08-08-2018
		03:12 PM
			6 Comments (6 New)
		I recommend the implementation of architectural warnings in the error log for detection of architectural mistakes. It would be nice if this could be toggled from the error log (like warnings) or had a viewer of some sort.
So far, I only have one architectural error that I’d like to catch, but I’m sure there are many others as well. Feel free to add suggestions for more architectural errors you'd like to catch.
Below I’m demonstrating the problems with bi-directional library dependence when using ppls. In this case the warning should state that: “Bi-directional dependence detected between Lib3 and Lib4”.
Note:
The VI hierarchy does not help at all 😞
:No help from VI Hierarchy
