3 | |
3 | |
2 | |
2 | |
1 |
Hello all!
The standard LabVIEW plugins are great but operate based on Ctrl + Key shortcut. This means that after a while almost all of your keybord keys can be occupied by a shortcut.
Please add an interface for defining commands in the QD ComboBox, which could be used as a more extensible option over single keys.
Example - a Dialog command could be invoked like this:
Ctrl+Space -> Dialog Text -> Ctrl + C
Example community package implementing this can be found here: https://forums.ni.com/t5/Quick-Drop-Enthusiasts/Class-QD-Plugin-Package/gpm-p/3992772
Thank you!
